Fun codes
There was oil in the front passenger O2. I tried my best to get as much out with a cloth. Any suggestions on what to clean it with? I really hate the idea of putting water/degreaser on it since its electrical wires.
) Just spray it into the connector, shake out the excess and blow dry (if you have a compressor, or let it air dry). Make sure all the connectors are completely plugged in (you will hear a "click")
There is an aerosol electric cleaner, I use brake clean (also an aerosol) because I have a lot of it sitting around. Something that will cut grease and evaporate quickly (so it doesn't have time to eat the plastic
I have been able to eliminate the one code.. I'm replacing both bank 1 sensor 1 and bank 1 sensor 2 o2 sensors tomorrow. I did pull out one of the wires for the bank 2 sensor 2 plug on the wire harness because I didn't realize how it "clipped" in. That could be an issue?!
PO154: O2 sensor no activity circuit (Bank 2, Sensor 1)......... **GONE**
PO161: Oxygen O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
P016O: O2 Sensor Circuit No Activity Detected (Bank 2, Senor 2)
PO141: O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
PO134: 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
