Fun codes
Old Jul 16, 2012 | 06:11 PM
oilspotLR's Avatar
Originally Posted by Disco Mike
Did you check, inspect and clean the 02 connections, if there is any oil in them, that could be your issue
There was oil in the front passenger O2. I tried my best to get as much out with a cloth. Any suggestions on what to clean it with? I really hate the idea of putting water/degreaser on it since its electrical wires.
Old Jul 16, 2012 | 07:01 PM
Bkreutz's Avatar
There is an aerosol electric cleaner, I use brake clean (also an aerosol) because I have a lot of it sitting around. Something that will cut grease and evaporate quickly (so it doesn't have time to eat the plastic) Just spray it into the connector, shake out the excess and blow dry (if you have a compressor, or let it air dry). Make sure all the connectors are completely plugged in (you will hear a "click")
Old Jul 16, 2012 | 11:01 PM
oilspotLR's Avatar
I took brake cleaner to the front passenger O2 sensor clip. Not only was it full of oil it wasn't all the way plunged in. That could certainly be part of my issue.
Old Jul 24, 2012 | 11:05 PM
oilspotLR's Avatar
I have been able to eliminate the one code.. I'm replacing both bank 1 sensor 1 and bank 1 sensor 2 o2 sensors tomorrow. I did pull out one of the wires for the bank 2 sensor 2 plug on the wire harness because I didn't realize how it "clipped" in. That could be an issue?!
PO154: O2 sensor no activity circuit (Bank 2, Sensor 1)......... **GONE**
PO161: Oxygen O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
P016O: O2 Sensor Circuit No Activity Detected (Bank 2, Senor 2)
PO141: O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
PO134: 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
Torancis_LR
Jul 5, 2009 07:56 PM
