Funny wear on rear pads
Old Jul 2, 2018 | 06:48 PM
vishrb's Avatar
Default Funny wear on rear pads
Stumped by the condition of my rear pads. Land rover discovery 2. Back brakes were getting kind of weak. Pulled off the back left and found the inside pad next to piston completely warn. The outer pad 80% new. Tested the slider pins and one was seazed. Figured that was issue. Used c clamp and pushed piston in with out issue. Pulled off right wheel and examined the pads. Same issue. Inner pad warn completely and outer with plenty of pad left. However both pins worked as normal. Pushed piston in with c clamp without issue.
Why was the inner warn and not outer? If the piston had seazed would I be able to push in easily with c clamp?
Old Jul 2, 2018 | 11:37 PM
Spam2021's Avatar
Check the mounting brackets that hold the pads in, I had mine have a worn spot where the brake pads ride on. There was a noticeable valley that was keeping the brake pad from mpving as it should. I wish now I would have taken a picture to show. But i was getting crazy squealing with new brake pads, I resurfaced with a file just enough to give pad a smooth surface to ride on. Afterwards no squealing and it felt better when braking. Just an idea,
Jose
Old Jul 3, 2018 | 12:42 AM
Richard Gallant's Avatar
What is this a thing this weekend wierd brake issues, my left rears were worn vertically much thinner at the lower edge than the top. Caliper "appears fine", replaced the pads marked the disk with a sharpie and took a test dive. Sharpie marks were removed as expected.
Old Jul 3, 2018 | 04:02 AM
shanechevelle's Avatar
My wife just told me the front right caliper is froze...lol, I asked her how do you know that, she says its pulling to the right and making a noise.
Are these trucks sync'ed or something?
Old Jul 3, 2018 | 11:23 AM
vishrb's Avatar
I am replacing the pads, rotors, and cakioer carrier. I am not going to replace the caliper at this time. Hope that is the right call. I suppose a good flush is a good Idea as well. These trucks can be goofy!
Old Jul 3, 2018 | 12:30 PM
vishrb's Avatar
Jose
I deff had a pin seize on one side. On the other everything seemed in reasonable order. I will clean everything up. See how it goes. I opted for expensive pads and rotors so hope I don't miss anything.
04duxlr
Oct 15, 2015 08:42 PM
toofaroffroad
Mar 21, 2015 04:55 AM
s10lowrider1994
Nov 29, 2014 10:19 AM
pipjack
Jun 10, 2010 01:18 PM
focusontheworld
Jun 27, 2008 07:48 PM
