Gas Grade - High, Medium or Low
Old Nov 21, 2005 | 12:49 PM
disco1's Avatar
Default Gas Grade - High, Medium or Low
What grade gas do you run in your Discovery?
Old Nov 21, 2005 | 12:56 PM
forbin10's Avatar
Default RE: Gas Grade - High, Medium or Low
medium or high pending on prices, the low grade, from what I am told with gum up or just screww up you filters and lines I don't know if that is true but I don't want to find out.
Old Nov 21, 2005 | 03:39 PM
Landzu's Avatar
If you have the high compression V-8 you need to run the highest octane
you can get. If not your knock sensor will work over time and retard the
timing (less power, less mpg's) if the knock sensor quits you will mess
up a motor for the 2 dollars you save on a full up.
Here in the flat lands I get 92 or 93 octane.
Would you run the wrong oil?
Old Nov 21, 2005 | 03:42 PM
Benhamtroll's Avatar
I've tried all three. I noticed a fairly big difference between regular and mid-grade, but almost no difference between mid-grade and premium. It's hardly a scientific process, but I've come to the conclusion that the extra $.10/gallon you pay for premium just isn't worth it.
Old Nov 21, 2005 | 05:33 PM
Landzu's Avatar
Benhamtroll you said " but almost no difference" to me it's about
piece of mind and many more miles.
Old Nov 21, 2005 | 10:19 PM
mikemeyer0's Avatar
Depends, in the winter (when cold) i can get away with 87 octane. In the hot months or wheeling, i need to run the 89-91 octane, or the beast will start to ping and detonnate.
by the way forbin10, lower octane will not plug or gum up yuor lines.
omarica7
Mar 11, 2014 08:12 AM
Francopacks
Aug 10, 2012 08:39 PM
georgetrieste
Feb 5, 2008 01:45 PM
xb70valkarye
Appearance & Camping Set Ups
Aug 25, 2006 01:28 PM
