Is it a good idea to preventatively replace my radiator?
Old Oct 24, 2019 | 11:49 PM
Brandon318's Avatar
Originally Posted by Discorama
If you are at it, add the OEM oil coiler.
Doesn't this involve changing the front engine cover?
Old Oct 25, 2019 | 01:00 AM
Discorama's Avatar
Yes, but a sandwich adapter does the trick too. I got one with integrated thermostat which is even an improvement over the standard design.
Old Oct 25, 2019 | 06:34 PM
Extinct's Avatar
The plastic on the OEM radiators was very poor quality, end tanks often split, dumping coolant and overheating the engine and blowing the headgasket. Hoses get soft as well and rupture. Given it is 15 yrs old unless it has been replaced you would be wise to replace all non-metal components pre-emptively. If you are diligent checking the coolant level you can skip the water pump, but it will eventually wear out as well. Most components fail in the 120-160k mile range based on my ownership of a even dozen.
dougn
Oct 15, 2019 08:12 PM
The_OGCJR
Jan 21, 2018 01:47 PM
Ursula
Aug 24, 2016 10:49 AM
bmeier
Jan 13, 2015 09:16 PM
chrisusvi
Apr 27, 2007 09:48 PM
