Got a temperature gun -- Measured the cooling system
Old May 11, 2018 | 02:10 PM
  #51
Sixpack577's Avatar
This^
Old May 11, 2018 | 04:18 PM
  #52
redwhitekat's Avatar
His heater core hoses were cold anyway even if it was 50 % plugged the supply line would be hot
get another stat and start over
  #53
Saturnine's Avatar
You are totally correct. Gonna bypass it for now since were getting into summer.
I just want to simplify things as much as possible right now until this gets sorted.
Originally Posted by Dave03S
You realize that unhooking heater core hoses makes you have to start over bleeding the system? Adding coolant through the bleed screw only works if you keep the system closed, it is the final step in the process only to be done when the engine is stone cold from sitting overnight.
By bypassing the heater core you are essentially starting over so no need to do the bleed screw thing until you are done experimenting.
If it helps you isolate a problem then fine, but keep this in mind, you're wasting time doing the bleed screw trick and then reopening the system.
Old May 11, 2018 | 04:22 PM
  #54
I'm telling you and I have been hearing from other people that the 180 Tstats are hit and miss lately
Old May 11, 2018 | 04:54 PM
  #55
Best4x4's Avatar
Sounds like a manufacturer made a boo boo on labeling their temp’s to the proper batch for sure! Very easy to do during the assembly process.
Best way to avoid any issues like that = boil the sucker before installing it vs spending all that time tearing it apart and doing the job several times.
Old May 11, 2018 | 04:59 PM
  #56
Saturnine's Avatar
Ugh, well the new britpart is in the car so.. yeah.
Something i was pondering though -- I measured the sensor on the lower intake manifold (which is new) and while it was reading 215 on the UG the brass fitting itself and the hard coolant pipe going into the lower IM was about 120ish. I IS CONFUSED
Is the lower IM temp sensor the only one that feeds signal to the UG / temp gauge?
Old May 11, 2018 | 05:20 PM
  #57
Saturnine's Avatar
Oh right, there is the one at the outlet of the radiator.. Hmmmm
Old May 11, 2018 | 05:50 PM
  #58
Best4x4's Avatar
It’s more for SAI function (sensor on the radiator). Upper sensor is what gives the actual temp reading.
Old May 11, 2018 | 09:12 PM
  #59
Those infrared guns are not the greatest they will not work properly on certain surfaces
Old May 11, 2018 | 09:15 PM
  #60
rcdoeshair's Avatar
Originally Posted by Saturnine
Hmmm.. ok. Where is said lower temp sensor? On the Rad?
I second this .I have a temp sensor just hanging under my truck .I just assumed it was to the outside temp measurement, now I'm a little more nervous. Lol I've glanced, not looked hard, at the bottom of my radiator and don't see where a plug could even go. If this is the lower temp sensor, is it possible, that where the sensor goes has a plug in it and I'm just not seeing it? Mine runs pretty warm on average. OBD scanner clocks it anywhere from 190-230. Temp Gage just stays in the middle .
