The Great Head Gasket Adventure
Old Jun 20, 2010 | 06:40 PM
  #91
vandev's Avatar
Default not really...
Originally Posted by pilsner
See what I am dealing with? WHERE IS THE DAMN NUT?! The nut is inside the bell of the pulley! How do I get to it to loosen it? The best suggestion I can come up with (other than the one that involved C4) is that I remove the water pump with the fan on it still in the hopes that once I get it out I will be better able to work with it, perhaps cut the pulley in half with a cut off wheel or drill out the bolts from the back side. I take out the bolts on the pulley and it all comes apart right? Then it is a simple matter to re thread the holes and get new bolts from local hardware store, correct?
thanks guys
P.S. does it occur to anyone else that I am the only person who has these kinds of situatiations as an occurance of daily life?
Not really, the guys who designed and built the motor in the first place..and put the fan on correctly...well the motor is still a big Fu$cking POS... so dont feel bad....
Old Jun 20, 2010 | 07:10 PM
  #92
lordmorpheus's Avatar
There is about 0.0 inches of room in there. I am pretty sure that when the engine spins it is TIGHTENING it. but that is just a guess. and yes I had a few laughs at my own expense too so that is excusable.
If there is *any* space betwen the fan and the pulley, even 1/16"...could you fabricate a wrench using thin stamped steel or something? It sounds like it could be at most finger tight. I think anything wrench-like, no matter how flimsy appearing due to the thin-ness, might be able to get the nut loose.
Maybe? Would save you from having to cut something you would have to pay $ to replace.
Old Jun 20, 2010 | 09:32 PM
  #93
cranky's Avatar
Default Try this
I don't know if this will work or not but it is worth a try:
get a heat gun or blow torch and carefully (very carefully) heat the sensor on the front of the clutch. It may just lock up enough to be able to unscrew the assembly by hand. It shouldn't need much more than a soft heat - enough to expand that coil thing!
- just rember the fan is plastic! you only need to heat that coil in the middle of the clutch. And if you burn it to the ground don't blame me. LOL
________
VAPORIZER-INFO
Old Jun 21, 2010 | 02:38 AM
  #94
lipadj46's Avatar
That was already suggested above
Old Jun 21, 2010 | 05:18 AM
  #95
cranky's Avatar
Sorry I didn't understand your post!
But do you think it might work?
________
Philippine girl Webcam
Old Jun 21, 2010 | 09:28 AM
  #96
DiscoArt's Avatar
What did I tell you about the beer at the start of this thread?
Old Jun 21, 2010 | 12:08 PM
  #97
pilsner's Avatar
Yes I remember the warning about the beer at the start of the thread. <insert I TOLD YOU SO here>
I figure that it took a special kind of idiot to pull catastrophic failure out of the teeth of absolute success in this manner.
So wednesday the other h2o pump gasket gets here from AB and I am going to take the water pump off with the fan assembly still attached. I will drop the whole assembly off at the machine shop where I got the heads done. Hopefully he will be able to drill out the old bolts, reverse the pulley into the correct orientation, and then rethread the bolt holes for me.
I am quite proud of myself for getting the entire rover engine reassembled though. My wife was betting against me.
Old Jun 21, 2010 | 02:57 PM
  #98
pilsner's Avatar
How hot would it need to get to activate that metal coil? like hairdryer hot or torch hot?
Old Jun 21, 2010 | 03:20 PM
  #99
rtonder's Avatar
Since you may end up cutting the pulley apart anyway, try drilling a 5/16 inch hole in the pulley belt face about where the nut flanges would align. Pick up a quality 1/4 inch pin punch, put a point on it with a grinder, then slide it through the hole and strike the nut flange in so it turns counter clockwise from the front. Perhaps hold the pulley with a strap wrench if it jerks. Spray a bit of penetrating oil in as well.
The small hole shouldn't affect the strength or balance, and you may need more than one to get the right angle on the nut. Best of luck.
Old Jun 21, 2010 | 03:22 PM
  #100
pilsner's Avatar
Thanks. I am going to try the heat option first then if that does not work then maybe your option will get a go.
