The Great Head Gasket Adventure
Old Jul 9, 2010 | 03:16 PM
  #191
DarylJ's Avatar
Originally Posted by pilsner
any suggestions on best way to check for a vaccum leak?
Starting fluid works. Spray a little through the straw at the suspected source. If the engine surges, you found a way in that shouldn't be there.
Old Jul 9, 2010 | 03:37 PM
  #192
pilsner's Avatar
No luck with cleaning my IACV. It was dirty as hell in there but it didnt seem to help much if at all. And yes I cleared the codes before I restarted her. Going away for the next week or so but I will order those parts on payday and see if I can find a vaccum leak when I get home.
Old Jul 12, 2010 | 12:37 PM
  #193
dcarr1971's Avatar
This is a great write up...keep us in the loop as to what happens...
Old Jul 12, 2010 | 02:44 PM
  #194
Wolkesan's Avatar
it seems to idle fine (other than being a little rough) but as soon as you put it into gear and/or accelerate it dies out. I will go out in the morning and let her get warm then put the ODBII reader on her and gather some real time data for you guys.
Whats the best way to check for a vaccum leak?
If you don't have one, a vacuum gauge is really helpfull in narrowing down what to look at and does not cost much. Connect with hose and t fitting. Helpful chart: http://www.international-auto.com/fi...uum-gauges.cfm
Here is a good article on using fuel trim as a tool to help diagnose engine vacuum leaks. If you have or have access to a Hawkeye diagnostic scanner, you can see the short and long term fuel trim values. Not sure what other scan tools might show you the same information. That way you can figure out if a vacuum leak is the likely culprit before spending a whole day looking for a bad hose.
http://www.aa1car.com/library/fuel_trim_wellsmfg.pdf
Also:
http://www.aa1car.com/library/vacleak.htm
Old Jul 21, 2010 | 11:03 AM
  #195
yloDiscoII's Avatar
What's the latest?
Old Jul 23, 2010 | 02:53 PM
  #196
greenwade's Avatar
You still having troubles man? That is no fun. I am glad to see that the 5th brigade made it home safe!
Old Jul 30, 2010 | 11:19 AM
  #197
pilsner's Avatar
Just got back from vacation and havent gotten around to screwing with the rover yet. I will prolly spend saturday trying to find a vaccum leak that may or may not exist and removing my fuel filter to see if it is clogged or not.
Old Jul 30, 2010 | 11:26 AM
  #198
pilsner's Avatar
Why am I unable to find fuel filters for D2s on any website? I tried AB and roverland to no avail. Is it part of the fuel pump assembly or something? I was under the impression that it was an inline filter located on the frame rail behind the driver's side rear tire, is that not correct? (im not at home so I cant just go out and crawl under her to look or check it out in the RAVE manual)
Anybody got any info on where to get a fuel filter at?
Old Jul 30, 2010 | 11:47 AM
  #199
lipadj46's Avatar
Yes, thanks BMW
Old Jul 30, 2010 | 11:50 AM
  #200
discomedic4's Avatar
Originally Posted by lipadj46
Yes, thanks BMW
X2. You must replace the entire assembly. Sucks for you DII owners.
Perfectphoto
May 31, 2019 08:27 AM
sumeet
May 24, 2015 08:15 PM
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
