The Great Head Gasket Adventure
Old Jul 6, 2010 | 09:01 PM
  #181
pilsner's Avatar
ok, got it. thanks. I will let you know how it goes tomorrow after I clean up and reconnect the purge valve
Old Jul 7, 2010 | 02:08 PM
  #182
pilsner's Avatar
P0440 evap purge valve unsealed. That makes perfect sense considering that I went out to the rover this am and check the purge valve and the little metal clamp thingy on the rear of the purge valve was seated but not clasped. So I cleared the codes, restarted the truck, and I still have the stalling problem. Fault codes for O2 sensors and ABS remain. I dont care about the ABS stuff right now I just want to get the stupid truck running under her own power.
Incidently the check engine light is NOT on, even when she stalls out. Odd?
Can this much engine problem be just from bad O2 sensors?
idea? suggestions?
Old Jul 7, 2010 | 03:34 PM
  #183
lipadj46's Avatar
idea? suggestions?
No bad O2 sensors just cause a little bit of a rough idle and cause the engine to run rich. Describe how it runs/stalls again. How is your fuel pump/pressure? Maybe the filter got gummed up sitting there half full? Also you sure all your clamps on the air intake lines are clamped tight? If it starts then stalls there could be a vacuum leak somewhere.
Old Jul 7, 2010 | 07:19 PM
  #184
pilsner's Avatar
it seems to idle fine (other than being a little rough) but as soon as you put it into gear and/or accelerate it dies out. I will go out in the morning and let her get warm then put the ODBII reader on her and gather some real time data for you guys.
Whats the best way to check for a vaccum leak?
Old Jul 7, 2010 | 09:21 PM
  #185
discomedic4's Avatar
I realize that I am only a DI owner but I just had the same problem with mine. Turned out to be the IACV or the TPS. Replaced both with a new one, had my indie reset my ECU. Right as rain now. No more stalling when I give it gas.
Old Jul 7, 2010 | 09:41 PM
  #186
lipadj46's Avatar
Good thought check you idle solenoid and make sure that it is hooked up properly, you can even squirt some carb cleaner up in it to try to clean it out.
Old Jul 8, 2010 | 02:28 PM
  #187
pilsner's Avatar
What is an IACV? And where is my idle solinoud located? Sorry I'm not at home with my RAVE to look at
Old Jul 8, 2010 | 02:37 PM
  #188
Bundu's Avatar
Banned
Iacv...
Old Jul 8, 2010 | 02:48 PM
  #189
lipadj46's Avatar
They are the same thing, that tin can looking thing in the pic above
Old Jul 9, 2010 | 03:02 PM
  #190
pilsner's Avatar
ok, so AB is gonna get me for some money this paycheck. 2 x O2 sensors and one IACV. poop. I hate giving them money for no fun stuff...
Of course I will try cleaning it and then reconnecting it first.
any suggestions on best way to check for a vaccum leak?
