Harmonic balancer question
Check this out from Miami British; LAND ROVER CRANKSHAFT PULLEY DISCOVERY 2 II RANGE P38 LHG000060 USED | Miami British Corp. got to be worth thinking about. New one from Atlantic British not cheap Crankshaft Pulley / Harmonic Damper (Genuine Part # LHG000060 ) - Land Rover ancillary components from Atlantic British.
If it is on its way out then you should think about getting it done unless you want to do it yourself. Hardest part is getting the pulley nut off the crankshaft and tightening it back to 340 lbf. ft and hold the crank with a crank locking tool.
