Harmonic balancer question
Old Dec 10, 2015 | 06:44 PM
mose802's Avatar
Default Harmonic balancer question
Disco is in the shop for front engine oil leak. Mechanic called me today and said the harmonic balancer will eventually fail. New one $500. Ouch!!! No extra labor, should I replace it or wait? Rebuild it?
Old Dec 11, 2015 | 05:44 AM
drowssap's Avatar
not for $500 when a used one is $50
Old Dec 11, 2015 | 06:24 AM
Alphamale's Avatar
Check this out from Miami British; LAND ROVER CRANKSHAFT PULLEY DISCOVERY 2 II RANGE P38 LHG000060 USED | Miami British Corp. got to be worth thinking about. New one from Atlantic British not cheap Crankshaft Pulley / Harmonic Damper (Genuine Part # LHG000060 ) - Land Rover ancillary components from Atlantic British.
If it is on its way out then you should think about getting it done unless you want to do it yourself. Hardest part is getting the pulley nut off the crankshaft and tightening it back to 340 lbf. ft and hold the crank with a crank locking tool.
Old Dec 11, 2015 | 08:04 AM
Paul Grant's Avatar
I have plenty of good, used pulleys with their damper for a fraction of the cost of a new one. Let me know if I can be of help to you. I'm sure I can save you some money!
Old Dec 11, 2015 | 10:24 AM
mose802's Avatar
Awesome thanks for the help, I inspected it myself today. Shaft looks good it's just the rubber damper is starting to deteriorate some.
Old Dec 11, 2015 | 11:23 AM
WNYErikDiscoII's Avatar
Former Sponsor
I sell new Genuine ones for $420 if you cant find a good used one and don't want to overpay at AB.
Old Mar 20, 2023 | 09:02 AM
mackendw's Avatar
You still selling new genuine ones ? for the 4.6L Discovery 2 engine?
If so, how much?
Old Mar 20, 2023 | 11:14 AM
XRAD's Avatar
quote " Disco is in the shop for front engine oil leak. Mechanic called me today and said the harmonic balancer will eventually fail. "
ummm...they will all eventually fail...what does your 'mechanic' mean....is the rubber almost all gone? or a few small cracks like we all have?
Alex_M's Avatar
That's Erik at Lucky8. Should be able to check their website or call them. Not sure if he still frequents the forums or not.
Old Mar 20, 2023 | 01:51 PM
mackendw's Avatar
ah, so the prices have gone up since then...snikes!
Nic900
Jan 1, 2020 08:02 PM
TGerman
Oct 13, 2014 12:03 AM
zhirkhan
Jul 1, 2011 08:06 PM
shonuff93
Oct 7, 2009 07:24 AM
Brad S1
Mar 10, 2007 11:34 PM
