Head/Brake Light Issues
Old Jan 25, 2012 | 03:47 PM
Kalel's Avatar
Default Head/Brake Light Issues
Okay, just doing a shake down after my off road adventure, and found some light issues. One the low beam headlights are not working. They worked before the trip and afterwards, we went to dinner, and then one went out now both are out. High Beams work fine.
Brake Lights: This apparently was happening before the trip, no one told me though. With the lights on, I depress the brake pedal, the 3rd brake light lights up and the main lights go dim. But when not depressed they shine bright, kinda like they are working backwards.
Old Jan 25, 2012 | 10:32 PM
Fuse 10, inside fuse box, right hand low beam. The real low beam, not the 5 watt city light bulb.
Fuse 9, inside fuse box, left hand low beam.
Beyond that it is bulbs, wiring, switch, etc. All in the RAVE electrical manuals.
Page attached for brake lights, sounds like grounds disturbed, possibly trailer light connector in right rear corner of truck (inside behind cover), pehaps the sockets in the lamp housing.
File Type: pdf
Old Jan 25, 2012 | 10:33 PM
Kalel's Avatar
I keep forgetting I downloaded RAVE. Thanks SB.
Old Jan 26, 2012 | 09:32 AM
Also, you may have just burned out your low beam, it happens. If that is the case, replace both head light s so you will have the same color and brightness from both sides.
For the 3rd. brake light, try cleaning out the light socket, water can get in there causing corision.
Old Jan 26, 2012 | 08:27 PM
Kalel's Avatar
3rd brake light works, but when the lights are on, the L/R brake lights go dim when depressing the brake pedal. And get real bright when not depressed. Kinda like they are wired backwards.
Old Jan 26, 2012 | 09:36 PM
Pull this connector and check: (see attached)
pin 1 = green white = turn signal
pin 2 = ground
pin 3 = red / black = tail light (or red / orange, depends on side of truck)
pin 4 = green / purple = brake
Or maybe some one installed incorrect bulbs and jammed them to fit.
File Type: pdf
Old Jan 27, 2012 | 06:49 AM
Jarvise's Avatar
Hello buddies,
I have some problem with my rare brake lights. I didn't understand the problem. How can i check it out? I need your help
Old Jan 28, 2012 | 10:22 PM
Kalel's Avatar
Both fixed, somehow I blew both front headlights one right after the other. And the rear started working correctly after I took the bulbs out a re-installed them. Thanks for the help.
bradical
Sep 25, 2011 06:55 PM
wesley64
Sep 25, 2011 03:09 PM
jhewitt1111
Dec 26, 2010 04:46 PM
bavarian_range89
Dec 29, 2007 02:56 AM
bigbris1
Jul 3, 2007 08:02 PM
