Head Gasket Needed - what would you do??
Old Feb 24, 2010 | 10:37 PM
mherson's Avatar
Default Head Gasket Needed - what would you do??
I am into my 2001 Disco II SE7 for about $5000.
It has 150,000 miles on it.
I have new shocks, springs, brakes, thermostat, rear hub, an several cosmetic improvements.
Getting the 3 Amigos too.
Overall Disco holds road well, shifts well, and looks great too.
I checked the coolant and see that its empty, blowing white smoke from exhaust, bad smell, etc...I need a new Head Gasket.
I was quoted $1600 for gasket, bolts, wires, plugs, oil, coolant - seem fair.
He is going to send the block out to machine shop prior to completing the job.
would you guys put this much $$ into an engine with 150,000 miles. Do you think it's worth it? i appreciate your feedback. thanks!
Old Feb 25, 2010 | 07:20 AM
DiscoJag's Avatar
Default Head Gasket
He's going to send the block out to a machine shop ? Maybe he's going to send the heads to a machine shop, that would sound reasonable. If that is the case, that's not a bad deal. You could do it yourself and save $1,000, if you have time and a place to do it. Otherwise, get it done and you'll be good for another 150K miles.
Old Feb 25, 2010 | 10:03 AM
You are burried in the truck, can't sell it that way unless you sell it for $3000 or less. I would get the head gaskets replaced and drive it for the next 5 plus years to get your monies worth out of it.
How mechanical are you, have you thought about doing the head gaskets yourself?
Old Feb 25, 2010 | 11:09 AM
okdiscoguy's Avatar
Fair price for what is being done. You can do it yourself if you have the resources and time. I would do it myself, but the price is right.
As Mike said, you won't sell it for much if it is broke. Fix it and keep it up. You will have a great truck for years to come. I have spent about $1K over 4 years on a very neglected truck. If the motor blew tomorrow, I would just put another in.
Old Feb 25, 2010 | 07:21 PM
mherson's Avatar
thanks for the reply guys. i will go for it
how many miles do you think these engines can go after getting something like this done?
also, i asked if he could use magnecor wires and he said he uses ngk.
are those any good?
-matt
Old Feb 25, 2010 | 07:40 PM
Willie00d2's Avatar
I am doing my headgaskets now. Take the rocker shaft assemblys apart and clean them good. I found that my oiling holes in the rockers were clogged, no oil could get to the push rods.
Willie
TheAustin
Jan 8, 2013 12:15 AM
Disco S2
Apr 5, 2012 10:26 AM
calebbo
Oct 12, 2011 09:54 PM
NiveK1970
Sep 9, 2009 05:26 PM
RovingRiesensCubed
Jan 12, 2008 01:11 PM
