head gaskets being done
Well, while the wallet is open:
1. Have them check fuel pump PSI, the test fitting is located in a hard to reach spot that they will uncover.
2. Strongly consider new water pump, oil pump, timimg chain, and front cover seal (part of the package).
3. Be sure you have greasable front prop shaft and rear drive shaft. If not, you are in the zone for it coming apart and spearing the transmission.
4. While they have heads off, valley pan gasket will be replaced, this provides opportunity to inspect / replace lifters, rods, camshaft.
Gordon Bombay
12-22-2009 10:31 AM
