head gaskets being done
Old Nov 19, 2011 | 02:17 PM
gavone1976's Avatar
Default head gaskets being done
I am getting the head gaskets and getting all new wires and plugs.Any suggestions on other things I should have done while they have it all apart?
Old Nov 19, 2011 | 02:29 PM
Well, while the wallet is open:
1. Have them check fuel pump PSI, the test fitting is located in a hard to reach spot that they will uncover.
2. Strongly consider new water pump, oil pump, timimg chain, and front cover seal (part of the package).
3. Be sure you have greasable front prop shaft and rear drive shaft. If not, you are in the zone for it coming apart and spearing the transmission.
4. While they have heads off, valley pan gasket will be replaced, this provides opportunity to inspect / replace lifters, rods, camshaft.
glassman66
Jul 17, 2012 08:31 AM
armored
May 30, 2011 07:07 PM
Gordon Bombay
Dec 22, 2009 10:31 AM
kman3786
May 5, 2009 07:56 PM
kjordan
Oct 22, 2008 08:21 AM
