Heads up regarding using a non LR purge valve -- make sure it is "genuine" Hyundai
Old Jul 5, 2017 | 10:45 AM
Chrisw7562's Avatar
I went with new ss hose clamps when I replaced the valve. Guess I'll pick up some 5/16 line today at lunch. I like replacing the older hoses when I can, too much heat under the hood on a good day and time + heat does a lovely number on rubber.
Any particular type of 5/16 line?
I just went with an LR gas cap back in the early days when I ordered most everything from Atlantic British.
Thanks for the tips today!
Old Jul 5, 2017 | 10:55 AM
akrover90's Avatar
Originally Posted by Best4x4
I've found the Stant gas cap at Wal-Mart for 6.00 is identical to our OEM LR gas caps (also made by Stant). If you're careful you can pop it apart, use the new lower half (important part), and re-use the OEM top and retain the little lanyard that lets it hang.
Do you happen to know the Stant/walmart number on this (10819?)? I'd like to grab one at lunch, but don't have my truck here to compare. I replaced my purge valve a little over a year ago (purchased at Hyundai parts deptarment) and the P0441 has come back three times since. I clear it and then months go by until it comes back. So, I've just assumed it was the has cap.
Old Jul 5, 2017 | 11:06 AM
Best4x4's Avatar
10819 sounds right. I bought two as spares and I can double check when I get home, but 99% sure that's it.
Old Jul 5, 2017 | 11:11 AM
akrover90's Avatar
Cool. Thanks. That one looks right to me, but that method has cost me in the past, so I wanted to check.
austinlandroverbill
Apr 1, 2015 06:26 PM
Willie00d2
Sep 14, 2014 10:44 PM
Fast951
Sep 4, 2014 04:58 PM
range_time
Sep 24, 2010 10:01 AM
Parts4x4Landrover
Member Group And Special Buys
Jan 22, 2008 05:47 AM
