Heated Windshield retrofit/upgrade not working
Old Nov 14, 2008 | 12:57 AM
phatduc's Avatar
Default Heated Windshield retrofit/upgrade not working
Disco II '99 that DIDN'T come from the factory with the winter options. (I installed the heated seat switch kitand they worked great, burnt a heating element in the driver side chair, but that;s another post). I live in MT so I figured when it was time to replace the windshield anyway, whataheck, swap it out for a heated unit.
- I had the heated windshield installed. Plugged into the connectors on either side under the hood as advertised elsewhere on the forum (Thanks guys!)
- Purchased the heated windshieldswitch and sure enough the 'blank' plug in the instrument switch cluster above the coin tray had a wired connector that fit the new switch perfectly. There were several 'blank' plugs and I didnt think to check the others to see if they too had connectors that posibly could be the correct one (will check them next).
- Installed a new relay into the plugthat has the heated windshield symbol in the fuse box next to the battery.
- Checked the two 40amp fuses powering the heated windshield- both good.
Started the car andexpectantly pushed thebrand new, looking like it was born there, heated windshield switch.Theindicator light on the switch which is supposed to light up when it's ON, didn't light !! I must have missed something.
Any ideas guys? Thanks in advance, Dave
Old Nov 14, 2008 | 03:05 AM
Urban Panzer's Avatar
Default RE: Heated Windshield retrofit/upgrade not working
yep, the BCU (Body control Unit)needs to be re-programmed by Testbook or Rovacom to tell the car a heated screen is fitted
Old Nov 15, 2008 | 12:09 AM
phatduc's Avatar
thansk Urban. Well that;s a minor detail considering the nearest dealer is 500 miles away. Any ideas?
________
Drug Test
Old Nov 15, 2008 | 12:37 AM
ORIGINAL: phatduc
thansk Urban. Well that;s a minor detail considering the nearest dealer is 500 miles away . Any ideas?
[:-]god that place you lot live in is huge LOL ............
Erm ideas, well there is no shortcut, it has to be reprogrammed as the BCU controls the heated screen circuit / timer. It does not have to be a dealer, it can be any independant shop, BUT they must have either Testbook,T4, Rovacom or Autologic diagnostic equipment specifically for Land Rovers.
The other "long shot" and im not even sure if its possible, would be to post you BCU to a dealer, they could maybe install it in another D2, re program it and send it back............
Old Mar 21, 2012 | 10:31 AM
Joshman's Avatar
@phatduc,
I cannot find the tutorial for adding heated screens to the Disco II. You referenced one in your post. Can you PM me the link?
I am also interested in adding the winter package (lack of heated seats was almost enough for me not to buy this particular rover) so any tutorials you have for the retrofit seats, switches, etc., would be greatly appreciated. Also, your take on whether it was worth it or not would be great.
Thanks a lot, in advance.
Old Mar 21, 2012 | 12:11 PM
04SSHD's Avatar
Is there a switch for heated windscreen? I think I have one, and I don't know how to operate it if so...
Old Mar 21, 2012 | 12:38 PM
Joshman's Avatar
On the one that I test drove with heated screens, the switch was on the dash, under the radio, next to hazard lights and rear defrost button.
Old Mar 21, 2012 | 02:38 PM
04SSHD's Avatar
well, hell... There it is.
I guess I do have it
Old Mar 21, 2012 | 02:42 PM
Joshman's Avatar
The one to the right of hazards is for the windshield (shaped like a keystone), the button under it (rectangle shaped) is for the rear.
Old Mar 21, 2012 | 05:01 PM
jafir's Avatar
Also, when the BCU is programmed to know the heated windscreen is there, it will come on automatically when you turn the conventional defroster on.
I used a hawkeye to enable mine in the BCU.
Absolut-land
Feb 21, 2014 12:38 PM
Austin Capo
Jan 18, 2012 02:49 PM
Snafu / Disco Fries
Mar 7, 2011 09:21 PM
krazzz
Oct 21, 2009 07:34 AM
morfa
Dec 23, 2007 10:38 AM
