Heatwrap ?
Old Jan 19, 2023 | 06:58 PM
Rrr_bhb's Avatar
Default Heatwrap ?
Has anyone tried using heatwrap on exhaust pipe to reduce heat coupling onto the front driveshaft? Thoughts?
heatwrap example: SunplusTrade 2" x 50' Black Exhaust Heat Wrap Roll for Motorcycle Fiberglass Heat Shield Tape with Stainless Ties https://a.co/d/j1doBTs
Old Jan 19, 2023 | 10:21 PM
04disco2va's Avatar
Yes got tired of burning myself and wanted to protect the drive shaft. Used the design engineering wrap and their CAT covers. Worked great and looks nice. I do have to check the stainless ties from time to time they get old and break.
Old Jan 20, 2023 | 08:43 AM
TimInNova's Avatar
I got two of these:
Design Engineering 011003 Universal Catalytic Converter Heat Shield Design Engineering 011003 Universal Catalytic Converter Heat Shield
And attached them to the cats. They stand off the surface about an inch and dramatically reduce the radiated heat.
Old Jan 20, 2023 | 05:50 PM
Extinct's Avatar
Nice, I am been using the aluminum duct work pieces from Home Depot, but your solution is better @TimInNova
Old Jan 20, 2023 | 08:24 PM
ace10's Avatar
@TimInNova Read your review on AMZN... if you're still concerned about the fasteners working free, Rocksett threadlocker would be an excellent solution.
Old Jan 21, 2023 | 07:19 AM
XRAD's Avatar
timinnova, how are the bolts attached to the band straps?
Old Jan 22, 2023 | 02:40 PM
04disco2va's Avatar
Here is another option. These are just fastened using stainless zip ties. No issues with loosening for a few years now.
Old Jan 23, 2023 | 04:17 PM
XRAD's Avatar
I like DEI wrap. If you wet it before wrapping, it stretches a bit and gets nice and snug when dried out.
Old Jan 25, 2023 | 10:27 AM
TimInNova's Avatar
XRAD, there are these tabs that the bolt goes through, then the metal strap (red circled items).
TimInNova
Feb 6, 2023 07:47 AM
DiscoJax
Aug 15, 2022 10:14 AM
EricTyrrell
Jul 23, 2012 10:10 AM
rich
Sep 7, 2009 12:59 PM
cst756
Jun 5, 2008 09:01 PM
