Help
Old Jun 8, 2020 | 06:29 PM
Easton Collins's Avatar
3rd Gear
Default Help
Good afternoon gentlemen, I am looking to buy a Land Rover Discovery 2004. I am trying to familiarize myself with the issues that might occur upon purchase. The one problem the owner says he has is this. I can't find much about this problem what kind of help can you give me regarding this issue? "It goes into park but won’t come out of park unless you reach down and press a button."
Old Jun 8, 2020 | 06:33 PM
The Deputy's Avatar
Brake light switch bad? To get the shifter to move, you have to apply pressure to the brake pedal, once this is done, it sends a signal to the shifter lockout to release. Maybe someone rigged up a bypass switch?
Old Jun 8, 2020 | 06:39 PM
3rd Gear
Okay, thank you for your quick response. should I worry about this as a deterrent from buying the vehicle, or would replacing the switch be worth a try?
Old Jun 8, 2020 | 06:40 PM
Dave03S's Avatar
It's a $20 switch that takes 10 minutes to change.
You would be better off worrying about what other backyard fixes they may have done.
Old Jun 8, 2020 | 06:42 PM
3rd Gear
Awesome, I'm also trying to find a reliable place to find cost-effective parts. Do you recommend any particular website?
Old Jun 8, 2020 | 07:23 PM
Extinct's Avatar
Rockauto, ebay, Advance, Oreilly, Rimmer Bros, and Amazon have the best repair parts prices generally. Rovers North and Atlantic British for more specialty items. The shifter issue is likely a brake switch, sometimes they get out of adjustment, sometimes they plastic tab breaks off, sometimes they just come loose. Occasionally they will just outright fail, but it is a $20 part and 10 minute repair. Search the forums for pre-purchase inspection threads.
Old Jun 8, 2020 | 07:51 PM
XRAD's Avatar
Exactly! Better drive it for a while, and get under it and really look at everything. Listen to the engine. Check the electrics. Squeaks? vibrations? sparks? history? receipts? There is no way of telling if this will be a good disco for you, but that is the crapshoot of buying one. Maybe you get 10 years, maybe 10 days, before a major breakdown........
I would not buy one as a daily driver unless I really knew the vehicle beforehand....
mln01's Avatar
Or AutoZone. It's a commonly available part.
You can test whether or not the brake light switch is bad by turning the key to Position II or starting the truck, then stepping on the brake pedal. No brake lights = bad brake light switch.
handsome rob
May 12, 2017 10:10 AM
jamestfl
Mar 29, 2017 07:01 PM
G Reeves
May 18, 2013 12:05 PM
discolucy
Oct 28, 2009 12:43 PM
mellyagaunce
May 18, 2009 08:08 PM
