Help with codes please
Ok I drove through a big muddy area yesterday and hit a few puddles, nothing a disco can't handle right?
A bit afterwards I felt the car shudder at idle without RPM gauge fluctuating
Got home a few miles away and all seemed well. I drove to work this morning and found the service engine soon light on.
Checked codes after work at autozone I got
P0152 - o2 sensor?
then P0301 and P0305
Anything to do with the puddle? What should I do?
Drives fine like nothing is wrong except with a random shudder here and there at idle
P0152 - o2 sensor?
What color are your plug wires, if grey, they are junk and and would cause the 2 mis-fires. You need 8 mm silicone wire that won't leak when wet throwing codes. as for the 152 code, bank 2 sensor one is gone and you should replace both front's to get your air/fuel ration equal on both banks.
I have yellow ones they were recently replaced. During a top end rebuild for headgasket
I forget where and what they are called. Kings something? I believe they were 8mm
Is bank 2 on the passenger side?
Is it at the bottom?
If it dries out should it be fine?
Looks like you got misfire codes.
You can plug codes into this site:
http://enginecodemaster.com
It has most of the codes from the RAVE in it by now.
