Help. headlights randomly turning on while parked
Old Sep 3, 2016 | 08:09 PM
94svt50's Avatar
Default Help. headlights randomly turning on while parked
My 2003 discovery just started acting odly. Randomly while parked the doors will lock on their own and the headlights will turn on and off every few minutes. Occasionally it will flash the blinker lights as well. It's been doing this off and on for several days. If I go out it unlocks with key and starts up just fine. It only does this while sitting parked. I have no idea where to even start troubleshooting. Any one have any ideas of what could be going on?
Old Sep 3, 2016 | 08:33 PM
samroy92's Avatar
Have you checked the battery? Make sure all the terminals are tightly secured, that would be my first step.
Old Sep 3, 2016 | 08:38 PM
94svt50's Avatar
I did check the battery. It's about a year old yellow top and it turns engine over very nicely. Cables tight and clean, I went on and disconnected the battery for the night due to the annoying headlights shining at the house
Old Sep 4, 2016 | 09:01 AM
Red5's Avatar
Remove the battery from your FOB and see if it continues. If not, the issue is with your key, maybe just needs a new battery. What you describe happens when you push or hold the lock button.
Old Sep 4, 2016 | 09:09 AM
94svt50's Avatar
Very true, will try it. Thanks
Old Sep 4, 2016 | 12:29 PM
94svt50's Avatar
Took the battery out of remote and the problem seems to be fixed. I think the fob is bad, when I was jostling it around getting the battery out the little red light on fob kept flashing like I was pushing buttons. Thanks again for the help!
Taylo135
May 5, 2015 04:35 PM
ldutch
LR2
May 18, 2014 08:25 PM
marshman 442
Jul 23, 2011 10:23 AM
EASTLAND
Jul 30, 2007 05:47 PM
jmerrill
Apr 4, 2006 06:37 PM
