Help ME!! Intake manifold removal
Disco II.
We removed all 12 bolts in sequence from the manual and are at the step where it simply says "Remove inlet manifold". How do we pry that bad boy off without breaking anything? I put a pry bar in the head of the front valley gasket bolt head and tried to pry up the manifold but it will not release.
I know the four bolts are off of the coil but the injectors and fuel bar are still in (injectors are disconnected).
What to do???
What to do???
Disco II.
What to do???
What to do???
twin6 (01-25-2017)
The manual on page 447 indicates remove the inlet manifold as step 18. Step 19 says remove the bolts you speak of....
