help me remove this part! or just tell me how
Old Oct 26, 2015 | 02:57 PM
Wilson7287's Avatar
Originally Posted by driftology
so close yet so far. made some progress today. im down to the head bolts that won't budge. don't want to rush and wreck so i am done for the day. as far as the sai pipes go i ended up having to remove them to get to one of the rear head bolts. one of the ends freed up and that made pulling the other side much easier. wish i had that custom tool tho!
Good luck man! Those are terrifying to remove! They take a lot of strength.
Old Oct 27, 2015 | 07:30 AM
Paul Grant's Avatar
Next time use a little heat on the nut end of the SAI pipe. Take a propane torch to the nut. It will work a lot better than any easing oil.
Old Nov 1, 2015 | 12:59 PM
driftology's Avatar
back at it again! head gasket came out intact it pretty much looked new lol. the cylinder in question looks like its covered in oil while all the others look dry or maybe even a little lean.
Attached Thumbnails help me remove this part! or just tell me how-20151101_131157.jpg   help me remove this part! or just tell me how-20151101_131207.jpg
Old Nov 1, 2015 | 02:40 PM
Bom2oo2's Avatar
Did you clean combustion chambers or it is exactly the way it looked after tear down,,
Because from what I see in pic the chamber that you call as "in question" is the way it's supposed to be,, seems like the other 3 are the ones that have a problem, if engine has been running for some time the inlet valve's should look dark & covered with carbon & exhaust valves should look reddish brown color,,,,,,
Seems like 3 of the chambers also had carbon buildup at some point, which is expected,, but looks like they have been washed with something & valves never should be that white sooth look,,,,,
How do the pistons & cylinder walls look,?
Old Nov 1, 2015 | 03:20 PM
driftology's Avatar
that was pre-clean... the pistons are all dark just like the cylinder 4's head. i thought it was odd that all the valves look that way. is it possible that bank 2 was remapped lean since cylinder 4 was not firing properly. the last car i pulled apart that looked like that was having fueling issues. after cleaning everything up, cylinder 4 is the cleanest. it has obvious signs of steam cleaning from coolant. with no damage to the gasket and no other obvious signs of water leak i'm leaning to believe that i have coolant passing up the sleeve well on to shoving it all back together tomorrow...
Old Nov 1, 2015 | 03:25 PM
R0VERGUY's Avatar
I'm sorry I didn't see your post sooner or I might of been able to help with those SAI manifold pipes. I know you already got them off but I'll still tell you how I remove them if you want.
On the back side of those nuts is a fitting that has a square head you can get a pair of channel lock pliers or crowfoot wrench on to hold it while you use another pair of channel locks to loosen the nut.
As for the "modified tool", if you have a spare wrench to bend then great, but I suggest getting a "crowfoot wrench set" like the one below. I used them on this pipe the first time I had to remove it because it was really on there. Now I just use 2 pairs of channel locks. Find what works best for you I guess.
Sears.com
BrianTN
Jun 28, 2014 09:55 PM
wheelgarage
Oct 1, 2011 03:12 PM
sk_adams
Mar 20, 2010 06:07 PM
caleb
Jan 6, 2010 11:26 AM
rosalind
Aug 7, 2007 09:26 PM
