Help me trace my ABS foul
Old Nov 24, 2006 | 01:13 AM
Brad S1's Avatar
Default Help me trace my ABS foul
I checked the fuses, it was good, unless there is more than one ABS fuse... ABS light is on, cant figure out the problem... ideas?
Old Nov 24, 2006 | 10:42 AM
Default RE: Help me trace my ABS foul
Year and model?
Are you talking about the trio of lights, are you brakes acting up?
Mike
Old Nov 24, 2006 | 03:14 PM
scubasteve's Avatar
We had this same problem with my Wife's Disco....I think it was because the brake pads were wearing as there is a sensor. I think the sensor picks up vibrations or something that trips the light, or the trio of lights that we were experiencing. I wonder if there is a way to clean the sensor? Also, after replacing the pads and rotors, the lights were tripped again a few times during the break-in. That is what leads me to believe that it is a sensor. I may be way off.....so I hope someone else chimes in here!
All that being said, I would check your brake pads. My wife's Disco no longer trips the lights and it's been almost 500 miles since the pad and rotor change. I used EBC and they are working great!
-Steve
Old Nov 24, 2006 | 04:07 PM
ORIGINAL: Brad S1
Brad, where did you go????
Do you still need help???
Mike
briandmozy
Aug 9, 2014 06:58 AM
JumPeR04
Sep 21, 2012 10:52 AM
Brad S1
Aug 30, 2006 12:31 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
