Help with my 2000 disco 2 tranny
Old Dec 28, 2010 | 06:08 PM
JeffnKerrie's Avatar
4th Gear
Default Help with my 2000 disco 2 tranny
I just bought a 2000 discovery 2 for my wife, got a good deal because it needed a fuel pump. I ordered a fuel pump and had it put in got it started was running rough (would only idle) had a mechanic put his computer on it and it needed a Mass Air Flow sensor got that ordered and installed along with new plugs and it seemed to run fine. It had a little issue with tranny slipping on inclines so I figured I would check the fluid and it was black (like burnt motor oil) since it was the day before Christmas I figured I would change the fluid. After I did that it would not go into gear, when I put it into any gear it is almost like being in neutral there is a small hint of change. Please tell me I won't need a new transmission.
Old Dec 28, 2010 | 06:49 PM
lipadj46's Avatar
How much fluid did you get out an how much went back in? Does not sound promising.
Old Dec 28, 2010 | 07:00 PM
4th Gear
got out about 6 quarts and put in about 6 quarts I didn't change the filter I have a mechanic that is going to change it tomorrow
Old Dec 29, 2010 | 05:56 AM
lipadj46's Avatar
The filter is just a metal screen, can't hurt but not sure it will help. Dropping the pan will be good to see if there are any metal chunks on the magnet. How are you getting it to the mechanic?
Old Dec 29, 2010 | 07:57 AM
Before you turn a mechanic loose on your truck, send me your number and I'll call you right back, you do have problems.
Old Dec 29, 2010 | 05:50 PM
4th Gear
I use a mobile mechanic I've used him before on my other vehicles and he's pretty reliable for minor stuff. It's working now new filter and "9" quarts of fluid. It made a pretty big difference in the shifting still has a little hesatation shifting from 3rd to 4th. Thank you for responding. I still have some things left to do to it I have the three amigos lit up on the dash still have that to figure out
Old Dec 29, 2010 | 08:32 PM
lipadj46's Avatar
For the amigos find someone to read your abs codes or rent/buy an abs amigo
03discoman
Dec 25, 2009 09:59 PM
skunkridge
Oct 8, 2009 08:29 AM
boz44okla
Aug 30, 2009 10:16 AM
m1943
Aug 6, 2007 05:56 PM
r1dad
Nov 12, 2005 12:19 AM
