HELP!!! NO HORN or CRUISE!!!
Old Sep 20, 2010 | 08:50 PM
hilltoppersx's Avatar
yes its two different problems. check the line for a vacuum leak on teh cruise control. as for the horn i would disconnect the battery wait 10 mins. that unscrew the 2 hex screws on the back of the wheel releasing the airbag unit. that will allow access to the horn assembly. I would make sure all wires are secure back there. The problem is you can't pull the horn buttons apart. if they come apart they are broken for good and you need to replace the whole assembly. the wires that connect to the contact are very fragile as well so check all wiring. just make sure you disconnect the obviously the airbag is a pyrotechnic device.
Old Jan 6, 2011 | 04:32 PM
fuctifano's Avatar
Thanks for the help.
Cruise vacum was just loose and cracked. Snipped and replaced, job done.
mwood2121
Mar 23, 2011 01:31 PM
texmbr
Dec 4, 2010 08:53 AM
sratican
Nov 10, 2010 12:33 AM
lipadj46
Aug 13, 2009 07:47 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
