HELP: Oil pan removal at a hault
Old Feb 26, 2014 | 03:52 PM
  #21
ZGPhoto's Avatar
Originally Posted by br0keit
In the future...just cut/drill the bolts and leave the cross member off. There is no possible way a bar with those tiny bolts can be used for support. I'm under the assumption it's there so stuff doesn't flip up from the road or fall down and that's it.
Yep, that's the way to do it.
Originally Posted by earlyrover
"In the future...just cut/drill the bolts and leave the cross member off. There is no possible way a bar with those tiny bolts can be used for support. I'm under the assumption it's there so stuff doesn't flip up from the road or fall down and that's it."
__________________________
Where, when, did you get your automotive engineering degree? Are you willing to accept liability for doing such a thing? This is among the most ridiculous things I have ever heard.
And where did you get info from Land Rover? I know I did, but all I'm seeing from you is speculation.
Old Feb 26, 2014 | 09:06 PM
  #22
br0keit's Avatar
Have you ever seen the crossmember in question? It's held on with 4 tiny 8mm bolts on either side. They aren't even bolted directly to the frame. Instead they mount to a thin plate which has only 2 edges welded to the frame.
So basically...all that torsion force is distributed across 8x8mm bolts and about 12 inches of combined welding of 1/8in steel.
mike111
Jun 2, 2014 08:58 AM
MrFlea1
Dec 22, 2011 04:31 PM
Bryan H
Oct 8, 2010 12:06 AM
lipadj46
Nov 17, 2009 11:13 AM
91rover
Jul 27, 2007 05:04 AM
