HELP!! Oil Relief Valve ??
Old Sep 30, 2019 | 05:58 PM
Bal D Correa's Avatar
Originally Posted by Davis31052
Reposting from the What did you do today......
I’m in the process of installing my new oil pump gear set. I disassembled the oil pump pressure relief valve assembly for cleaning.
The shown parts below in picture one are the snap ring, cup with o-ring,spring and relief valve. Visible when the oil pump gears are removed. Got all that for sure.
Now, on the the other side of the timing cover, by the oil pressure switch, is another snap ring, cap with o-ring and spring. BUT no relief valve under the spring.
Am I missing something? Should there be oil pressure relief valve under both spring assemblies?
Hi, how did you take the cup off?
Thanks.
Fast951
Sep 26, 2019 09:15 PM
5kcstq
Sep 27, 2018 07:10 AM
Fast951
Apr 16, 2016 05:30 PM
4x4trouble
Feb 2, 2012 07:27 PM
aerokurt
Dec 5, 2006 06:34 PM
