View Poll Results: On a scale of 1-10, how would you rate 03' DISCO II sport?
Reliable
41.67%
Not so reliable
33.33%
Over sized paper weight
16.67%
Junkyard
8.33%
Voters: 12. You may not vote on this poll
Help please???
Old Sep 6, 2015 | 06:23 PM
  #21
R0VERGUY's Avatar
Originally Posted by LRDISCONEWBIE777
Found were the CPS is located. Took the Exhaust off and hell, my hands are still too big to work in that tiny space. Been trying for a few hours now. I've already got to experience the process of replacing the ignition coils and the old ones are still behind the engine block. I built the plug wires myself and the ignition coils were relocated on a bracket that a made myself. I'll try a new fuel pump first and if that does not solve the issue, perhaps I can find a way to bypass the CPS.
Whoa man, you really want to hack your truck up don't you?
Why didn't you just take the upper manifold off and replace the coils? And a CPS is way cheaper then a fuel pump so I wouldn't go replacing it yet. You can't bypass the CPS so you'll just have to figure out a way to get to it.
The CPS plug is connected to a bracket. You pry the plugs back toward the rear of the truck I believe. That should release the plugs (still connected) from the bracket. Then with one hand, reach up to the top plug and press in and hold the locking tab on the plug. Then with your other hand, gently pull down on the sensor and they should pop apart. It might help if you take the sensor off first before you try and unplug it. That way it might hang down a little further and give you something to pull on after to press the locking tab in. Hope that helps.
Old Sep 6, 2015 | 07:45 PM
  #22
LRDISCONEWBIE777's Avatar
Right now, I am waiting for a hydraulic pump for the lift in my shop. I am 6'4'', 300lbs. huge hands, big arms, big chest, big shoulders. Back to the ground and all of that jazz does not work, though I tried like hell earlier. lol.
Old Sep 6, 2015 | 07:56 PM
  #23
It was a few months ago when I relocated the ignition coils. Why did I do it? I did it because it made no sense to have to take the manifold off every time I had to change spark plug wires or the ignition coils. I'll take some pictures and post them. It really looks good and after I was done and all 8 fired correctly and in sequence. LOL...pay for new manifold gaskets, perform extra labor, and lay across the engine every time I have to replace spark plug wires and/or the coils? Nah. To change the plug wires, plugs, and ignition coils is now a 15 minute job. As for the thought of bypassing the CPS-no worries; it was a brain fart.
Old Sep 6, 2015 | 08:00 PM
  #24
I did notice how condensate drips/runs onto the CPS. So, when I install the new one, I'll make it water tight.
Paul Aspen
Nov 4, 2013 02:10 PM
tarpon66
Jul 27, 2011 12:38 PM
sawadeh
Jul 2, 2011 08:10 PM
Speed racer
Oct 11, 2008 10:56 PM
