HELP!!! Trans Stuck in PARK!!!!
Old Mar 4, 2019 | 02:05 PM
wjsj69's Avatar
Remove the f'in thing and float-test it in the nearest deep body of water. Or jumper 12volts to it and if it doesn't actuate, replace it. Your call. If your brake lights work and the brake fuse is good, the solenoid is probably bad. Also check your brake switch under the brake pedal. I think it's in the circuit too..
handsome rob
May 12, 2017 10:10 AM
jbkroh
Sep 15, 2012 04:24 AM
Cowtown1411
May 1, 2012 09:37 PM
rmace1
Jan 16, 2012 08:27 PM
dlkk
Jan 13, 2009 02:09 PM
