HELP! Won't turn off with key!
Old Feb 17, 2008 | 11:27 AM
dodge_mich's Avatar
Default HELP! Won't turn off with key!
After browing the boards for a while, I picked up a 1994 Discovery. It's in generally good shape, just needs a little TLC for the minor things.
It's been fine for the last few weeks, but today, the engine would not shut off with the key---this started after I cleaned the connections for the washer fluid pump, but I'm guessing that's coincedental.
Any quick things to check before I start tracing wires from here to Timbuktu? The rest of the accessories, relays, fuel pump, etc, shut off when I turn off the key...only the engine keeps running .
Old Feb 17, 2008 | 11:41 AM
Default RE: HELP! Won't turn off with key!
If the fuel pump shuts off then so will the engine when it runs out of gas.
The only thing that I can suggest is a bad ignition switch.
Can you remove the key?
Old Feb 17, 2008 | 12:39 PM
dodge_mich's Avatar
Well, I did some quick tracing and I seem to have found the issue...why this just started doing this now, I'm not sure, but it needs to be fixed anyway.
It appears that the prior owner had an auxillary fuel pump added, and they tapped into the coil posts for power. It starts/stops/runs fine without this aux pump hooked up. I'll be looking into what exactly it is, and if it's necessary. If it is, I'll just wire it up properly using a relay off the existing fuel pump harness.
Old Feb 17, 2008 | 02:00 PM
Where is your trk from? Is it from Alaska or someplace far north where it gets really cold?
In places like that they leave their cars running all winter long, if they shut them off they freeze up.
So I wonder is the previous owner used the aux fuel pump so that they could pull the key and lock it and still leave it running.
Old Feb 17, 2008 | 05:46 PM
dodge_mich's Avatar
It's a Wisconsin vehicle...the gas tank was supposedly replaced a little while ago. I used it for a variety of trips around town today with this mystery wire unhooked, and it ran just fine. Once all the snow melts off in the garage, I'll crawl underneath and see exactly what this wire goes to.
If anything else, might modify things and use it like you say (running with keys out). It's not absolutely freezing here, but there's times where it would come in handy.
Old Feb 17, 2008 | 06:14 PM
A friend of mine was stationed in Alaska while in the Air Force, he and a buddy shared a AMC Eagle and they let it run for 3 months at a time, literaly non stop for 3 months.
LA_Disco2
May 4, 2015 03:47 PM
southfloridadiscoII
Oct 27, 2014 09:36 AM
toad2
Jan 17, 2014 09:19 PM
southfloridadiscoII
Nov 7, 2011 08:10 AM
JasonM
Jan 17, 2009 10:33 PM
