Helppp
Old Oct 5, 2025 | 06:12 PM
Even's Avatar
Default Helppp
My 2004 was going in limp mode for the m s lights so I took it out cleaned it and put it back and now it won’t start. When I manually shift it using the lever under the car, the dash will recognise every gear except neutral and 3rd.
i need to fix this as it’s my only car and I go places. Any advice or suggestions? Thanks
Old Oct 5, 2025 | 07:19 PM
Externet's Avatar
Disconnect the battery, charge it properly, fully clean contacts and terminals bright with wire brush, re-install tight and come back with results.
Old Oct 5, 2025 | 07:59 PM
Even's Avatar
I had replaced the battery this week and cleaned the terminals. No corrosion at all everything was charging full voltage.
Old Oct 5, 2025 | 11:19 PM
Harvlr's Avatar
New batteries are often sold without a full charge. New batteries are also sometimes faulty. I think you should check your battery voltage with a multimeter, then report back. I think Externet is on the right track with his suggestions.
Old Oct 6, 2025 | 07:56 AM
sqlbullet's Avatar
Bad batteries have become increasingly common in recent years. I was helping my son replace his battery in his MB GL350 Bluetech, which is under the passenger seat. After wrestling it into place, which was a real chore, it was dead as soon as load was placed on it.
I now put new batteries directly on the NECO and run a "repair" cycle on them so I know they are good and fully charged.
Old Oct 6, 2025 | 11:24 AM
Even's Avatar
Haha decided to mess with the sensor again before I tried the battery. I adjusted it by loosening the two bolts that hold it on, then twisted it and heard something. I checked my dash and it finally read N. It started up no problem. Thanks for help guys!
Old Oct 6, 2025 | 06:38 PM
Harvlr's Avatar
I’m glad you figured it out. What sensor are we talking about?
Old Oct 6, 2025 | 07:47 PM
Even's Avatar
The xyz sensor. Sorry I didn’t clarify
Old Oct 7, 2025 | 08:52 AM
Harvlr's Avatar
Thanks
Old Oct 15, 2025 | 10:40 AM
longtallsally's Avatar
A quick addition to the issue: even if the terminals look good, follow the ground strap from the battery and make certain it’s mounting point is clean and good to go.
Glad you sorted it out.
NZPablo
Jan 12, 2023 07:05 PM
DiscoDrew9
Jan 7, 2018 08:52 PM
Mr R
Oct 16, 2015 04:32 PM
kerryslemon
Oct 21, 2011 04:45 AM
