High/low beam lights
Not sure I understand the simple question. Are you talking about flashing the highs by pulling the switch toward you, as though you were passing someone? They should work regardless of the position of the headlight switch. The only relay that you may have is for the daytime running lights, but it has nothing to do with the issue (I think) you describe.
hugo81 (12-29-2017)
Thanks
hugo81 (12-29-2017)
