High/low beam lights
Old Dec 2, 2017 | 04:42 AM
hugo81's Avatar
Default High/low beam lights
my disco2 does not turn the high beams on when the lights are off. But with the low beams on it changes to hi/low!
Is this the relay? Does anyone knows what’s the relay number please?
Or is this normal?
Thanks in advance
Old Dec 28, 2017 | 05:34 AM
hugo81's Avatar
Can you help me please?!
It’s a simple question...
Old Dec 28, 2017 | 06:42 AM
Red5's Avatar
Not sure I understand the simple question. Are you talking about flashing the highs by pulling the switch toward you, as though you were passing someone? They should work regardless of the position of the headlight switch. The only relay that you may have is for the daytime running lights, but it has nothing to do with the issue (I think) you describe.
Old Dec 28, 2017 | 07:25 AM
shanechevelle's Avatar
Need more information
Old Dec 29, 2017 | 02:21 AM
number9's Avatar
They won't momentarily flash or stay on by pulling the stalk back?
Sounds like an issue with the switch as mine works as advertised.
Old Dec 29, 2017 | 02:51 AM
hugo81's Avatar
Yes, that’s it, they don’t flash! I will try disassemble the switch.
Thanks
Old Dec 29, 2017 | 05:47 AM
mollusc's Avatar
If the high beams come on when the headlights are turned on, I doubt that it is the switch.
Perhaps in your area this is the correct behaviour?
Old Dec 29, 2017 | 09:42 AM
hugo81's Avatar
I have just checked with another TD5 and the high beam should flash when pushing toward...
Any ideas?!
Old Aug 31, 2018 | 06:23 PM
hugo81's Avatar
Already checked the switch and it looks fine...
can’t find the problem...
any help? Thanks!!!
oaty
Nov 14, 2017 06:20 PM
ftby55
Sep 20, 2014 03:44 PM
redspyder
Nov 4, 2013 11:31 AM
Disco_Dare89
Aug 8, 2008 05:13 PM
pdxdisco2
Oct 21, 2007 07:47 PM
