HIGH MILEAGE with NO MAJOR PROBLEMS
Old Mar 22, 2015 | 06:55 PM
SDinDS's Avatar
I have a high mileage Disco (209kmi) and since the rebuild 4 1/2 years ago, I've only replace a PS & water pump. It doesn't leak or squeak. All I do is change the oil and grease it. I attribute my success to the help and info on this forum and not letting anyone touch it.... except for the dealer who ran diagnostics on my ABS module and immobilizer. And now I'm sure that I've just jinxed myself and tomorrow every warning light will be on.
Old Mar 22, 2015 | 07:52 PM
Smith CH's Avatar
Both my Discovery's will hit 200k this year, I have had to do head gaskets on both of them 1 time. I dont consider head gaskets a major deal, not with these engines. No problems with the motors transmissions, or anything else. I keep the fluids changed, I use high quality fluids. I have broken a steering rod while off road. Both trucks are daily drivers. when I did the heads I completely resealed the motors and got new plugs, wires, thermostat, coil packs for d2, water pumps. those items had not failed, but I replaced them anyway. I had those items off the motor so I saw no reason not to replace them.
Old Mar 22, 2015 | 09:10 PM
Rover144's Avatar
Makes me glad I was able to get a 24 mos/24,000 mile Hendrix warranty when I bought my 2003/128,000 mi Disco II from the local Volvo/Subaru dealer last month. I had checked with other warranty companies and they refused coverage for the Discover series LR.
Old Mar 23, 2015 | 08:32 AM
dusty1's Avatar
never had a warranty, other than factory..
is it common practice for a company to turn down a vehicle? is it a black and white issue, like they have a book that says "go/no go"?
Old Mar 23, 2015 | 09:24 AM
99Discovery's Avatar
My '99 is approaching 124k. The previous service records indicate a head gasket and machine job from Great Basin Rover. Sadly, they didn't troubleshoot the issue and just fixed the head gasket.
I noticed the temp guage creeping above half at Mcdonalds, instantly parked it and bought an ultraguage. Running hot. Diagnosed as a plugged T-stat, replaced with the 180 TD5 and I'm doing great. It's been the most reliable $5k car I've bought (knock on wood).
The two biggest issues are easy to fix when you purchase: TD5 Tstat (with OBDII guage to read the actual temps) will keep you from Head Gasket issues (especially if you have upgraded to the "new" style).
Next is the serviceable drive-shaft which will prevent catastrophic tranny failure.
Then it is just routine maintenance and praying that your block won't slip a liner.
Old Mar 23, 2015 | 12:15 PM
Jawbox's Avatar
I'm around 170k with no major problems. Besides regular oil changes:
- I've replaced the waterpump and front seal
- the intake gasket
- an alternator
- the front driveshaft
However, I've got MAJOR rust issues and I've just started using anti-freeze this winter. At this point, the rust is going to do in the vehicle.
Old Apr 2, 2015 | 10:44 AM
BoeingBoeing's Avatar
2001 D2 with 167,602 miles. The compressor for the SLS failed two days after we drove it off the lot. The dealer replaced it. Other than that and the obligatory head gasket job I haven't had any expensive issues. I have done a lot of preemptive work on it (front drive shaft, crank sensor, t-stat, etc. Of course, I've done all the usual high mileage vehicle stuff like brakes, water pump and u joints, and I did recently do the coil spring conversation. It's been maintenance intensive for sure, but it has never stranded me...unlike my wretched (newer and lower mileage) Chevy Silverado.
Old Apr 2, 2015 | 02:22 PM
lndrover@carolina.rr.com's Avatar
Default 260,000 and still rocking
I have a 2000 disco II that i bought knew fully loaded. have 260,000 miles and have had very few issues. runs fabulous. love it. maybe has to do with bmw owning rover then and redesigning it. i will keep this baby forever. or as long as i am around. ha.
Old Aug 15, 2022 | 12:34 PM
efender's Avatar
4th Gear
I have not had any problems with my 2021 Defender, 8000 miles/12000km. I really like that car and i have been taking good care of it every day.
Old Aug 15, 2022 | 03:42 PM
adalton's Avatar
Auto forums are, understandably, full of posts about problems. I get that. But it would be great to hear from folks with high mileage Discos (guess that would be most) who have had no major problems. AND what they attribute their success to, be it a service schedule, anticipatory maintenance/replacement, a particular product etc.
Just hit 137k on my 03 and have no engine issues. Water pump and thermostat were replaced as well as some suspension items, but other than that it has been trouble free. Oil changes every 3k. Mobil 1 5w-40 Turbo Diesel truck oil and a mobil 1 filter every time. Watch your temps, listen for strange sounds, and go have fun.
Disco Mike
Nov 15, 2012 07:51 PM
Disco Mike
Dec 20, 2010 10:28 AM
nikos
Jun 12, 2005 02:05 AM
nikos
Jun 2, 2005 02:20 AM
