horn stop working
Old May 24, 2014 | 07:42 AM
grcurry's Avatar
Default horn stop working
Hello everyone, has anyone had problems with there horn shorting out. It started out fuse blowing once a week then just stop working completely. Any suggestion on fixing this problem
Thanks
Greg
Old May 24, 2014 | 07:48 AM
abran's Avatar
Can you apply power at the horn to see if it still works?
Maybe try replacing the horn if it's bad, if you keep popping fuses, then you will have to track down the wires and see if there is some damage.
Old May 24, 2014 | 03:51 PM
OffroadFrance's Avatar
Probably the relay gone 'phut'. I think it's no 13 in the fuse box under the hood you can check it by switching it with another there of the same type which is unused, no sure BUT, I think it's no 11 but check that out.
Résultats Google Recherche d'images correspondant à http://ww2.justanswer.com/uploads/molurch/2011-07-14_131254_land.png
This is the one in my truck D2 2003 TD5 but yours may be different.
Résultats Google Recherche d'images correspondant à http://thumbs3.ebaystatic.com/d/l225/m/mWdrgmCLpLA83RsH-ikYOHg.jpg
Read this for more info.
http://www.landyzone.co.uk/lz/f8/dis...em-128281.html
Old May 24, 2014 | 05:54 PM
schwaggy's Avatar
Could also be the spiral cassette. Does your cruise control work?
christiansmith6
Sep 14, 2014 04:45 PM
CapeRover
May 3, 2013 04:35 PM
Princess
Aug 26, 2009 07:22 PM
