Hose leaking coolant.
Old Aug 7, 2008 | 09:31 AM
nashville_disco's Avatar
Default Hose leaking coolant.
Good morning,
After arriving at work this morning I walked back out to the truck (99 d1 with 136000) to grab something and noticed coolant leaking out from under the truck. After opening the hood I found a hose with a pin sized hole in it spraying coolant. The hose comes off the block and runs into the cabin. My question is can I just replace the hose and refill with coolant? What else do I need to do? The last thing I want to do is blow a head gasket. Thanks so much in advance for any help!
Old Aug 7, 2008 | 09:54 AM
NiteTrain's Avatar
Default RE: Hose leaking coolant.
sounds like the hose that goes to the heater core. yeah, just replace and top off with coolant.
Old Aug 7, 2008 | 11:30 AM
Thanks so much! Do I need to bleed the system after I top it off? Also (stupid question) but how full should the coolant tank be? I can't see a fill line. Thanks again for the help!
Old Aug 7, 2008 | 04:12 PM
You shouldnt need to bleed the cooling system, you wont lose that much coolant. Open the resovoir bottle and you will see a "X", coolant needs to cover that.
D2 2003
Nov 7, 2017 07:41 AM
Sam95disco
Dec 6, 2011 08:52 PM
tango123
Nov 18, 2009 01:43 PM
bklahl
Feb 27, 2009 02:35 PM
opus13
Jun 4, 2006 03:15 PM
