How to change Crankshaft position sensor 2000 DII
Old Jul 29, 2013 | 04:53 PM
  #31
roverich's Avatar
So i finished mine after getting a part from a local land rover shop , Did not use it due to cost and got one from Napa with the same part number and manufacturer ..For 73 dollars ..Took me a little longer than you guys due to not being able to reach the bolts with my hand size..
Old Aug 30, 2013 | 01:56 AM
  #32
Phatrowles's Avatar
Just did this repair myself and it went great! You can access the harness plugin part from the top of the engine bay if you don't jack your truck up to high! I grabbed the connector with one hand and gently pried the other part loose with a long flat head screwdriver. Much easier than from below!
Great Write Up!!! Thanks a TON!
Old Jun 16, 2014 | 12:41 PM
  #33
discobob's Avatar
Got the heat shield off. It's got a hole in the front of it. AB says they don't stock it. Anyone?
Old Jun 16, 2014 | 02:46 PM
  #34
rvcoake's Avatar
Land Rover Discovery Crankshaft Position Sensor (Genuine Part ERR7354) Instructions
Old Jun 23, 2014 | 12:11 AM
  #35
Lilrich2u's Avatar
Hey there,
In the instructions on changing the CPS, it said to check 2 fuses inside the drivers fuse box first... Which two fuses? I'm going nuts trying to find them. I've got a 2000 disco... Found the relay and single fuse inside the engine compartment; nothing inside the cab, just the fuse to open the gas door. Any help would be appreciated.
Old Jul 9, 2015 | 02:04 PM
  #36
LeeHamm's Avatar
4th Gear
Default Thanks..
Thanks to everyone, for all the useful information, here. I just changed the CPS on my 2001 Disco II. I was given a $2000 USD quote and told the transmission had to come out. Thanks to all the details and comments here, I did it myself in a couple of hours.
My comments: I did this, from below, without dropping the exhaust. It helps to have long, thin arms, not short, muscular ones! The most difficult part, for me, was reconnecting the signal cable, as I couldn't get two hands into the space.
Gracias a todos!
Old Jul 9, 2015 | 06:54 PM
  #37
disc oh no's Avatar
$2,000??? What kind of an A$$hole did you get that estimate from? Were they going to replace the transmission while they were at it?
Old Jul 9, 2015 | 10:00 PM
  #38
acg's Avatar
acg
Lucky8 has an old video on this:
Old Jul 10, 2015 | 09:53 AM
  #39
LeeHamm's Avatar
4th Gear
Talking
Ha ha. I was out of the country at the time. My gf took the LR to one of these 'foreign vehicle' specialists for diagnosis. She told me when she got the quote and I put the brakes on. To be fair to them, they said they were not sure, had never done the job before and could make no guarantees etc. For a laugh, I'd still like to call my 'local' LR dealer [100+ miles away], for a quote.
Thanks acg. I'd watched the video a few times but it was still difficult to actually find the cps under the hood! The exhaust was my main clue.
Old Aug 26, 2015 | 06:38 PM
  #40
augustwillo's Avatar
In your opinion, anyone, is this a pretty easy fix to myself or should I get a mechanic to do it, who will charge me $250?
