How to clear codes / remove sensor
Old Aug 24, 2013 | 08:57 AM
robgusto's Avatar
Default How to clear codes / remove sensor
I am on SAI pump in my 03 Disco. I will get a 3rd pump but on my fix it list it is low priority and I'd like to clear the code. When I clear the code w my OBD II it comes back within a week. Is there any way to disconnect the sensor so that it does not send a code to the computer?
Old Aug 24, 2013 | 09:14 AM
Not likely - won't be the only Rover with a light on.... The SAI system runs thru functional tests to detect things not working, so unplugging will just make another code come on.
Old Aug 24, 2013 | 09:33 AM
robgusto's Avatar
Okay I will be trying to fix soon! I may need the dealer to fix/find leak/find out why pumps keep going bad?? OR I could get used to the light being on!!
Thanks for the quick response
Old Aug 24, 2013 | 10:08 AM
What are the exact fault code numbers?
Old Aug 24, 2013 | 05:03 PM
jfall's Avatar
All that pump is - is an air pump.
The pumps go bad as you are getting bad pumps from junkyards.
Get a pump from a low mileage Discovery.
TripleThreat
Jul 21, 2015 07:41 PM
JoeLena
Oct 20, 2014 08:39 AM
srockrae
Oct 6, 2012 11:19 AM
tbesselman
Apr 23, 2012 07:54 AM
rovernbama
May 15, 2006 03:03 PM
