How do I remove the SLABS ecu?
Old Feb 27, 2015 | 01:51 PM
Alex_M's Avatar
Default How do I remove the SLABS ecu?
Christ, I've spent an hour on this already. I must have a mental deficit, because I don't think it's supposed to be this hard. I've got the glove box out, as well as the bottom over panel. I got the bottom nut off of the bracket no problem, because I saw no way to get all the bolts off of the ecu itself. I couldn't get to the top one, so I figure I'll just remove the bolt from the opposite side. I get the SAI out of the way and remove what I think is the back bolt, no cigar. It's still attached. Send help.
Old Feb 27, 2015 | 03:41 PM
OffroadFrance's Avatar
Hi Alex, take a breeze through this Aus forum thread. The answer is there but as you have found already (like everything in D2's) it isn't easy. Good luck.
SLABS ECU replacement? - Page 2 - Australian Land Rover Owners
Old Feb 27, 2015 | 03:52 PM
Alex_M's Avatar
Thanks man, much appreciated. My previous search didn't turn up anything this useful.
Old Feb 27, 2015 | 05:56 PM
lordmorpheus's Avatar
Remove the under dash black cardboard shield with 3 (I think) push on / pull off fasteners (door trim panel tool helps). Remove the glove box from the dash (four bolts on bottom). Disconnect wiring from ECU. There are four nuts holding the SLABS to the engine ECU at the corners. 10mm IIRC. With some finagling, they aren't too bad to remove. Reinstall in reverse order.
Taking the glove box out is a HUGE help.
Old Feb 28, 2015 | 10:17 AM
Remember to disconnect your battery terminals before removing any ECU's as it might screw up the memories in them.
Old Feb 28, 2015 | 11:46 AM
Alex_M's Avatar
Yea, it's a parts truck so there hasn't been a battery in it in months.
I'll have to wait a couple days to try and get at it again. Had to make a last minute run to Nashville because my sister had a pretty severe allergic reaction.
Thanks for everyone's help.
Old Feb 28, 2015 | 03:31 PM
I hope all is OK now Alex, I can appreciate your concern having suffered from angioedema on and off for 35 years. The D2 will always be around when you get back anyways.
Old Feb 28, 2015 | 05:23 PM
Alex_M's Avatar
I've never heard of that so I looked it up, that sounds rough. My sister had a laundry list of allergies including but not limited to:
Wheat
Potatoes
Eggs
Soy
Red dye
Nickel
Laytex
Sulfa
Cleaning chemicals
There's more, but thats a few of the big ones. We try to keep a cap on it, but sometimes something slips through. She's ok now and we're on our way home. Thanks for the well wishes, I hope you can keep your angie demand under wraps too.
seaosrover
Apr 16, 2019 08:58 AM
Patrick Duffy
Nov 16, 2012 05:17 PM
MarvelVT
Dec 26, 2009 10:29 PM
ronthepoet
Aug 31, 2008 08:12 PM
ronthepoet
Aug 30, 2008 08:57 PM
