how do you remove radiator fan?
Thanks guys!! YES turn it toward passenger side!!
How do you remove radiator hose without hurting them? Haha sounds like a dump question but I did use heat gun to heat up the hose otherwise they stick so tight...
I'm going to swap out power steering pump tomorrow, thanks again!!
For me, usually releasing the hose clamp, and moving the clamp far enough back away from the thing the hose is clamped to, then gently twisting the hose at the base (where it covers the pipe) is enough to get it unstuck. Once the hose rotates freely around the pipe, I can pull it off with little effort.
... I didn't have to remove any coolant hoses when I changed my power steering pump last year. Not that I can remember anyway... but I also didn't remove the fan. I removed the entire auxiliary housing with the pump. It took a bit of contortion, but it worked.
edit: upon looking through RAVE, what I did follows the procedure. I could've sworn I did something different than recommended, and it worked. I will have to review my post from last year after I'm done reading all of the new threads
wheelgarage
10-01-2011 03:12 PM
