How on earth do you remove the oil filter?
Old Jul 19, 2010 | 11:38 AM
Brokenrover's Avatar
Thanks guys I couldn't see it bc of that plastic sheild and assumed it was different somehow. I guess everyone is allowed a moment of humility lol.
Old Jul 19, 2010 | 11:00 PM
Jason_B's Avatar
What is that other plug that he first removed. I was leaking oil from there pretty bad once, and it was hand loose. (back first when i got the truck). Just wondering if anyone knew off hand.
Old Jul 20, 2010 | 05:32 AM
Bundu's Avatar
Banned
On a 2002 you should have an oil cooler pipe attached there, the 2004 does not have an oil cooler and so there is just a nut to plug the hole.
Old Jul 21, 2010 | 11:13 AM
Jason_B's Avatar
Yea I just have the nut too, well it's more of a bolt or plug but no pipe. I wonder if it was removed at some point.
Old Jul 21, 2010 | 12:54 PM
bosshogt's Avatar
Can someone shoot a picture of the nut. I may tighten it a bit as I have found most bolts on this 4.6 come a bit loose after 7 years of driving. Like the bolts on my throttle body heater were all 3 loose. I still replaced it with the new kit.
Has anyone attempted to tighten the oil pressure sensor on the front cover with a deep socket?. I read a post where a guy had a oil leak and tighten it up. No more oil leak! A lot of stuff is simple. I could see where you would mistake that for a front crankshaft seal leak too.
Old Jul 21, 2010 | 05:27 PM
For the oil psi unit you need a big wrench, not sure what size it is, but its big.
I think it is the same as the drain plug on a DI.
calebbo
Oct 12, 2011 09:54 PM
wheelgarage
Oct 1, 2011 03:12 PM
caleb
Jan 6, 2010 11:26 AM
traffictech870
Mar 23, 2005 11:45 PM
