How the heck I get the caps off?
Still confused as to what that thing that looks like a puller is shown in the manual though. Any thoughts?
Spray them caps with some lube (pb blaster or wd40) and hammer the 1 1/6 socket on, that will snug the cap to the lug, then remove the socket. You should be able to get the socket back on without much hassle after that. The caps get messed up when tire shops whack them with oversized sockets on their air tools.
So, any tips on getting those out would be great. I'm hoping the spare tire has one. I have to take the cover off and see.
Land Rover Wheel Center Green Oval SIlver Sparkle - Land Rover Wheel Parts at Roverparts.com
They just snap in place from the outside.
So if you want to remove one from a rim you need to push from the inside out.
As for the lug nuts, took me 3 hours to do all 4 wheels my first time.
Like already mentioned, it MUST be a 6 point socket, lube the lug nut, hammer on the socket, use your breaker bar to break the lug nut loose.
Then take your hammer and pound the socket off the lug.
Move onto the next lug.
Welcome to Land Rover.
