How the heck I get the caps off?
Regular works fine maybe even better. As for the size of socket it's a tough call, in my case the 27mm fits best. The first thing I did when I bought my truck was replace half of the lug nuts. They were deformed and required an assortment of different size sockets. I was able to tap the sockets in with a rubber mallet and they came out easier than what I thought. About the breaker bar get the longest 1/2 inch that you can get, if you use a ratchet you could end up striping the pawl on the ratchet.
Done and thanks. 6 point 1 1/16th seemed to fit snug and best. I've got a decent 1/2" breaker that I will use with it as it is not something that would get much use from the tool chest anyway. Thanks! Driving her down to Philly tomorrow than from Philly to NYC Tuesday... so Murphy's Law clearly states since I actually *knew* I didn't have a tire iron I would surely get a flat tire. If I didn't check, I would have been able to drive 2 more years with no problems
The breaker and socket made quick work out of each lug nut. Went around the truck and broke each one loose, gave it a quick shot of WD40 and tightened them back up. The wheels must have been recently off as most were fairly easy. Either that, or I'm just all kinds of diesel and they were no match for the gun show
If you want to be able to take the wheels off again without problems, paint the contact area of the back of the wheel with never seize, and brush some on each stud.
I put never seize on just about every bolt I remove/reinstall unless its an area that specifically shouldn't have it (like fasteners that require thread locker).
WD40 is not a lubricant. It's a water displacer with some limited lubricating properties. It doesn't even work well as a penetrating oil.
Here is the carnage after rounding out the punk ***...This was my previous Audi 2.7T. Spent 2-3 hours carefully drilling it out to not damage the wheel:
2x on the WD40 I would replace that with antiseize, when that WD40 get hot and heats up from the heat of the rotor it will set like super glue.
Ive made the mistake in the past thinking it would make them easier to come off, it acted exactly the oposite.
