How involved is adding the 99-02 oil cooler to my 04?
The following 3 users liked this post by Richard Gallant:
I was going to do this. Still might. I have a oil cooler from a 2000. With the radiator out it's probably pretty easy via a sandwich adapter or the front cover ports. There is some chatter that the 04 front cover does not have the valve that routes the oil through the cooler, or something like that. I would probably use the sandwich adaptor if i go forward with it. At the moment I don't want to remove the radiator and deal with the coolant mess.
That was my takeaway from searching a bit too. This will never tow anything. The fully-loaded Tahoe burden goes to the 2002 though, so will probably pass on installing one for now. Maybe long-term, but the list of things is long and the time to do them is scarce right now.
