How to make hitch stronger
2002 Disco. I want to carry motorcycle on a hitch rack. Combined weight of everything is about 550 pounds so slightly over limit of 500 pounds tongue weight. On the same Disco I have put two dirt bikes on a double rack in the past at total just under 500 pounds and drove fine. Disco is stock wheels and suspension.
Any suggestions on how to beef up or strengthen the hitch since I'm over tongue weight?
X1 ................. but, weight = 550lbs PLUS inertial weight over any bumps then double that weight to 1100 lbs. Buy a bike trailer as it's cheaper in the long run. It's the ball hitch that is fragile as a casting not the towing brackets.
The 550 lb rating takes inertia into account, though. A trailer with 550lbs tongue weight is still going to experience inertial forces.
Probably a little less just because of how the weight is supported, but if the frame is in good shape I'd say still within tolerances. These things are typically rated at about 60% capacity anyway, according to an enginerd friend of mine.
but I don't fancy your chances of reversing that little lot
The Buell S3 is a chunky ole machine though.
..mg..
Jun 3, 2016 08:19 AM
Jared9220
Jun 8, 2014 11:49 PM
.Alan.
May 11, 2014 08:16 PM
VikingDiesel
May 22, 2009 07:34 PM
