How to make more leg space in the pasenger footwell
Old Apr 13, 2023 | 01:31 PM
Dunduin's Avatar
3rd Gear
Default How to make more leg space in the pasenger footwell
New here, and already have a question...
I have a Disco 2 (2002 - pre face lift). Bought to do up over time and use on our livery yard and smallholding, and because I live at the foot of wee hill in Scotland.
Husband is 6' with long legs and a wonky hip. He's finding the size of the transmission tunnel is causing his leg/hip to twist. I've just had the, what seems to me anyway, bright idea of either putting in longer seat rails or moving them back, if either is possible? And, if either can be done, does it impact on the location of the seatbelt?
Thank you in advance for any suggestions.
Old Apr 13, 2023 | 02:59 PM
jastutte's Avatar
I seem to recall reading a post where the rails were pulled and flipped around giving more room to move the seat backwards.
Unfortunately, I can't find the post anywhere.
Old Apr 13, 2023 | 03:27 PM
Dunduin's Avatar
3rd Gear
Thank you. I'll have another search. Good to know it can be done!
Old Apr 13, 2023 | 08:20 PM
hasullivan's Avatar
Originally Posted by Sandman614
I used to have a severe pain after I drove for a couple hours but after I modified the seat rail to allow some more rearward motion it has significantly helped. I think the main problem is the vehicle was only half way thought through for having drivers on the NAS side.
https://landroverforums.com/forum/discovery-ii-18/extended-seat-rail-disco-ii-34314/
https://www.aulro.com/afvb/projects-and-tutorials/125937-disco-2a-seat-travel-leg-room.html
from this thread:
Body fit for larger drivers
While adjusting the pedal position helped me, I do still plan on following the advice of Sandman and others in the thread.
Old Apr 14, 2023 | 02:33 AM
Dunduin's Avatar
3rd Gear
Originally Posted by hasullivan
from this thread:
Thank you kindly. It's the passenger side that's the issue as he rarely drives it (my car!), but definitely worth considering doing both sides. Will go read.
Old Apr 14, 2023 | 08:41 AM
hasullivan's Avatar
I assumed they were the same, just realized I should double check that. I will be doing the passanger as well when I extend them as our dog likes to sleep at the footwell.
Old Apr 14, 2023 | 10:32 AM
gecko951's Avatar
There might be some confusion here because most members of this forum are in the states so our passenger side is your driver side.
Here is a good article on extending travel for the seat rails:
MyRovers.com » DII Seat Modification-1.pdf
Old Apr 14, 2023 | 12:48 PM
Harvlr's Avatar
In Scotland you may have an easy time finding a P38 RR to swap for your D2. A lot more leg room, and as comfortable as D2 is, the RR is that much more comfortable.
Handy
Mar 9, 2023 10:37 PM
FlexibleVSAT
May 27, 2021 11:31 PM
discobob
May 21, 2020 12:48 PM
cegibbs3
Dec 5, 2017 08:44 AM
jimvw57
Jan 19, 2014 09:04 AM
