How to replace an amp in my 1999 LR Discovery 2
Old Mar 1, 2013 | 03:03 PM
tsalley's Avatar
8th Gear
Default How to replace an amp in my 1999 LR Discovery 2
My amp under the drivers seat has blown and I want to replace it myself but have no idea where to start. I want to bypass it with an after market amp. Are there any suggestions on how to accomplish this task? I had a "stereo repair guy" who said it would cost me $$$$$$ and he is not sure it can be done. Please help!!!
Old Mar 1, 2013 | 03:24 PM
SSL9000J's Avatar
Of course it can be done. Download the RAVE, look in the electrical section, it will tell you which wires are the inputs (from head unit) and outputs (to the speakers) to the factory amp. Match those up with the aftermarket amp and you're in business.
Old Mar 1, 2013 | 05:00 PM
bballjames's Avatar
It is pretty difficult. I'm not an expert, but from what I understand if you add an amp then you get into all sorts of issues with crossovers and stuff. I would just get another OEM factory amp on ebay.
Old Mar 1, 2013 | 05:25 PM
tsalley's Avatar
8th Gear
Default Thanks.
I have found a factory amp and I will replace it my self. All I have to do it just unplug the bad one and plug up the other, correct? Do I have to disconnect the battery as well?
Old Mar 1, 2013 | 05:28 PM
tsalley's Avatar
8th Gear
Thanks to everyone for their help. I am glad I joined this site and will help the next person if I can. I will also be back for more as I also need to replace my front sunroof.
Old Mar 1, 2013 | 09:32 PM
SSL9000J's Avatar
Not necessarily. Unless you plan on upgrading to some tricked out window-rattling system, the only thing that would really need crossovers are the subs in the rear, and they have their own amp anyway. But if you find a factory one on ebay, that will be your easiest option of course.
Old Mar 2, 2013 | 06:23 AM
tsalley's Avatar
8th Gear
Default Thanks Camel Toe LOL
Will do.
Old Mar 2, 2013 | 06:51 AM
Paul Grant (PM - he is a dismantler) ; or local boneyard?
Old Mar 2, 2013 | 12:02 PM
SSL9000J's Avatar
I have a factory 1998 D1 amp, no idea if it's compatible with a D2. It worked when I pulled it out about 6 months ago.
DavidG
Dec 9, 2016 03:34 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
elboy0712
Dec 19, 2010 02:48 PM
