How stiff should a CV joint be?
Old Mar 20, 2018 | 07:37 PM
Jeff Blake's Avatar
Default How stiff should a CV joint be?
I put in a new wheel hub and CV joint today. The CV I pulled out flopped around on the drive shaft with little friction. The new one (cheap part on RockAuto) is super stiff and requires maybe 20 lbs of force to move the joint around.
There was nothing apparently wrong with the original hub or CV, but I happened to have new ones laying around and I needed the old hub for fabricating a tire swingaway.
Old Mar 21, 2018 | 04:22 AM
The Deputy's Avatar
That's fine, new one has stiffer grease...old one has old worn thin grease.
Brian.
austinlandroverbill
Feb 16, 2017 07:57 AM
austinlandroverbill
Feb 12, 2017 10:19 PM
viper205
Jun 23, 2008 08:14 AM
dillhole
May 31, 2008 06:40 AM
Catsailor
Oct 9, 2007 05:16 AM
