How to turn off anti theft on 04 disco
Old Jun 23, 2016 | 08:18 PM
abran's Avatar
You are welcome. It will work. I have done it at least 5 times.
Old Jun 25, 2016 | 07:39 PM
Problem at the disco's Avatar
OK update, Withe the nail fix in mind, I looked at the Philips head screw driver I used in place of the pin to deactivate the anti-theft system and figure why should i cut both ends?
I used a #4 screwdriver Philips head, cut at 3 7/8 Inches ( $6.50 at store), Ground down the end on a wheel until it fit in the handle parts hole. Since I did not have a drill press and two broken bits later i figured I could not drill through the hardened steal I put a flat mark at 12 o'clock. Tapped out the hole with a screw thread and put a tiny screw throw to hole it. Flat part on the pin and screw in top to hold. My buddy was a mechanic for the airlines for years so he had the tapping and screwing I dear,
Hope that this can help someone and thanks again abran!! :-) Always one than one more way to skin a cat.
I will add any new things that I come across because I am holding on to my Disco II and stuff will com up.
Old Jun 26, 2016 | 11:00 AM
toofaroffroad's Avatar
Hi, wanted to jump in on this as it sounds like there are some experts.
I'm having kind of the opposite problem. I just bought my 2nd D2 and i do not have a remote fob. The driver door lock is broken but it's open. I can open and close the door, start and drive the truck...all good. but I can't lock or engage the alarm.
I've purchase the lock pin and i'm planning on replacing shorty. i'm wondering though, is there a way I can bypass the entire alarm system and only lock and unlock the driver door with key without it engaging the alarm and locking all the other doors?
I would love that. I can always lock and unlock the other doors from there central switch near there clock.
Maybe that idea is crazy?
Old Jun 26, 2016 | 11:58 AM
abran's Avatar
I'm no expert, but in my opinion it is not possible to disable the alarm system permanently.
montanajack12
Sep 15, 2020 08:44 PM
llPANCHOll
Jan 3, 2009 03:31 PM
AndrewPilkinton
Dec 5, 2007 06:07 PM
dikubec
Jul 28, 2006 05:22 PM
golfpro
Oct 21, 2004 01:52 AM
